how to determined gap
With my spark plugs, how do I determine what gap I should use? Stock gap for my motor is 044 but I have a blower so I usually close it a little. But what if I use racing plugs or just better plugs, can I or should I increase the gap to get a better burn? How would I determine the new gap size?
I don't know that "better" plugs would help. Usually newer plugs will have the sharper edges that promote spark jumping. As they get some mileage, those sharp edges wear down, making it more difficult for spark to form.
If you use forced induction and keep the same plug gap, you need to increase the voltage to your spark plug. So something that will help would be an ignition amplifier, like MSD. Then make sure the plug wires are in good shape, or the higher voltage will try to jump through other paths.
What I determined is regardless of the plug brand, if it's compatible with your setup, then stick with the stock gap for normally aspirated motors. If you have forced induction, you might want to decrease the gap, depending on the amount of boost. The one exception might be if the plug specifically requires a different gap.
AZ_Ford_Guy
31
07-04-2013 11:38 AM
ClatonK
Electrical Systems/Wiring
02-20-2007 03:57 PM
