1965 F 250 4x4
Hi and welcome to FTE.
Most people are swapping to a later model front axle with disc brakes already there, then working backward with the power steering. I could be wrong and would need to check the books but I don't think disc brakes were on the 44 closed knuckle. If you search the posts, there are a few guys that have mounted a steering box forward of the shock "tower", the main drag link then crosses over to pass side. This is how the later models were (70's 80's etc.) Ive posted a link for examples. Hope it helps, good luck, most of us are in the same boat....
https://www.ford-trucks.com/forums/1...-steering.html
Paul - Off the top of my head I think you need to be 1977?? and later for disc brakes. I found this post on FTE with links and more info. For my 64 resto - rebuild I am leaning toward the later model open knuckle Dana 60 front axle and a matching Dana 60 for the rear of same year donor I find. If memory serves me, this had disc brakes and big *** calipers but its been a long time since Ive seen one. Heres the link: https://www.ford-trucks.com/forums/9...dana-44-a.html
Dana/Spicer Products - Front Axle Codes 1961-1971 - FORDification.com
Front Axle, Dana 44, Closed Knuckle. 4:55 ratio, manufactured October 1963.
AXLE code stamped on the 2nd line...far right of the Warranty Plate, located on the left door face below the latch.
If the code is composed of 3 digits, the 3rd digit refers to the front axle, but Ford didn't always have 3rd digits on 4WD AXLE codes.
Ford/Dana front driving axle ID tag located under one or two of the bolts that retain the inspection cover to the housing. But today...many of these tags are missing.
Pic in post 12: Dana/Spicer 44-6F = Front driving axle with free running hubs: 1959/66 F250 4WD
