first 360/390 build..
Old 01-27-2015, 04:57 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,598 Likes on 1,303 Posts
Not sure how it could have run long enough to cause crank damage, as the engine would not run once the sprocket moved more than 10 or 15 degrees, maybe less, maybe a little more, but certainly not a full or even half turn.
That said, is this the 360 crank? If so, find a 390 crank and move onward and upward....
  #32
Old 01-28-2015, 10:42 PM
alaskan"70"f250's Avatar
alaskan"70"f250
alaskan"70"f250 is offline
that's what I though too.. but I checked it out and if I put the gear on the crank it wobbles it spins freely, with a new key it still wobbles, but with a new gear could this go away?
  #33
Old 01-28-2015, 11:47 PM
85e150's Avatar
85e150
Inspect both parts. If the crank has a groove in it or other visible wear, you are out of luck. If the crank looks good but the sprocket is visibly worn, you could try a new one. Can't expect it to last unless it's solid.
  #34
Old 01-29-2015, 09:10 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
do you have a Micrometer ? measure the crank and compare to a good crank . I have my original 360 on an engine stand in garage .I'll grab a measurement when i get home tonight .
  #35
Old 02-01-2015, 11:17 PM
Fellenz's Avatar
Fellenz
Fellenz is offline
Originally Posted by alaskan"70"f250
just went down to the machine shop to check on my parts. they said that the crank in unuseable because the timing gear on the crank has spun. therefore the crank is slightly smaller where the gear press fits on??? does this sound legimate? can I get an oversized timeing gear? if I need to get a new crank where can I get one cheapish?
I have both 360 and 390 crank cores if you end up needing a new turny stick.
Scifi266
03-07-2008 01:33 AM
DJOHNSTON78
24
12-20-2007 11:43 PM
allwthrrider
09-05-2006 11:32 PM
jseim44
19
05-19-2004 09:26 PM
Rat wagon
04-21-2003 11:09 PM
Quick Reply: first 360/390 build..
