1 Way Remote Start and key/fob consolidation on 2014 Expedition
Hi All,
I’ve had probably reviewed over 100 threads on remote starts and programming new fobs, but unfortunately I haven’t been able to answer my question. I hope you can all help. The backdrop:
* 2014 Expedition Limited with factory installed remote start (the 1 way, single button plug n play system).
* Truck has factory keyless and security system, so the add on was just the remote start module
* I currently have the 4 button key/fob combo and the single button remote start (see pic)
* Being a new Expedition, it’s an 80 bit security key
I read a lot of threads about people being able to reprogram their Expedition so the factory Ford fob also performs the remote start, so they can eliminate carrying two or three keys/fobs. Can I do this with my current key/fob combo somehow?
Or even better, I found this key/fob combo available online, which has the integrated remote start option as a 5th button.
Can I program this to perform the remote start? Information online regarding this key is limited. The seller says it can be used if my Expedition came with that exact model, yet as far as I know, NO Expedition with factory remote start comes with a 5 button key/fob combo.
I’m hopeful it’s as easy as programming the new key for ignition and remote functions, and then just “learning” the remote start button through the programming menu of the remote start system. I just can't determine if the frequencies will match, if I have to reprogram remote start to use two button presses (vs long hold) to start, etc, stuff like that
Any help is appreciated.
Thanks
Thanks
hldr
03-23-2017 10:34 PM
