special push rod belonging to the jacked rocker arm
I tore into my truck today to replace, what I thought the problem was, which was injector # 2. After I got the oil rail out, I noticed one rocker arm was crooked and not sitting on top of the push rod. The other rocker arm was really jacked. The plastic retainer clip was misplaced from it's original position. I don't believe that the dealer that I bought it from (who "fixed" the engine prior to me buying it) replaced all the rocker arms and the bridges. Here are the pictures of the push rod and really jacked up rocker arm. What are some ideas on causing this? My truck also has brand new heads with about 5000 miles on it. Should I replace the broken parts and see what happens or what?
I have seen this when I was a Caterpillar mechanic when a injector popped off and fill the cylinder with fuel and caused and Hydraulic lock. Now in most cases the fuel will drain out of the cylinder in to the crankcase bypass the rings after sitting. check and see if you have fuel in your oil pan
