WTF caused this??
https://cimg9.ibsrv.net/gimg/www.for...e796ea1ce6.jpg
jacked rocker arm https://cimg3.ibsrv.net/gimg/www.for...93df22aaf4.jpg special push rod belonging to the jacked rocker arm I tore into my truck today to replace, what I thought the problem was, which was injector # 2. After I got the oil rail out, I noticed one rocker arm was crooked and not sitting on top of the push rod. The other rocker arm was really jacked. The plastic retainer clip was misplaced from it's original position. I don't believe that the dealer that I bought it from (who "fixed" the engine prior to me buying it) replaced all the rocker arms and the bridges. Here are the pictures of the push rod and really jacked up rocker arm. What are some ideas on causing this? My truck also has brand new heads with about 5000 miles on it. Should I replace the broken parts and see what happens or what? |
I've seen high RPMs cause this.
Originally Posted by jswartz84
(Post 14846167)
Did that pushrod come from the number two cylinder
Could be injector of blown it's tip off Could there be a foreign object in the rocker carrier |
It's an interference engine so high rpm could definitely cause that if it floated a valve
Did you get number two injector out |
That's ugly and scary!!
2006 F350 4X4 |
Originally Posted by BLADE35
(Post 14846186)
(Post 14846184)
So did you get a diagnostic trouble code for number two cylinder
If so was it contribute DTC A little more info would help was it blowing a ton of smoke out the exhaust |
BENNY!!
He is BACK! You have been missed. Also on that bent pushrod. One end may of not been in the socket of the lifter all the way after the work. Sean https://www.ford-trucks.com/forums/p...ctureid=149188 |
(Post 14846322)
My little brother did the same thing when he reassembled his 6.0. Pushrod got off to the side of the lifters and made a mess.
Originally Posted by 78fordman
(Post 14846567)
Should there be any play side to side in the rockers or should they be tight? U ask cause on my other rockers I have side to side play
I have seen this when I was a Caterpillar mechanic when a injector popped off and fill the cylinder with fuel and caused and Hydraulic lock. Now in most cases the fuel will drain out of the cylinder in to the crankcase bypass the rings after sitting. check and see if you have fuel in your oil pan
