1948 F-3 Rat Rod Project
The wheels were on the truck when we got it. They won't be staying, though, because they are 8-bolt truck wheels. We'll be using 5-bolt wheels on the 'rod'.
Would love to post more photos, but everytime I try I get a message saying "Unable to upload photos"... is this because I haven't made enough posts yet, or do I have to get the annual membership to post photos?
Now, before you cut is the time to really think it through. I know that the Vic swap is sometimes done on 61-66s and IMHO it's too wide for that body style.On an early F series it may be even worse. I know it's a F-3 but they are not any wider than an F-2. IMHO Nothing ruins the look of a truck more than two big honking front tires out board of the front fenders. It's fine on the back but the front... not so much. F-6 fenders may help but that opens other cans of worms.
Just measure the Vic and think it through. There are plenty of other options if you find the Vic too wide.
I just looked at the pre- tear down pictures. Looks like the the truck was fairly original. Interesting it had the stainless windshield trim from a '51/52 to. Is it just the way the way the picture was taken or is there also a trim piece on the back window? If so I wonder what it is from, it wouldn't be a Ford part.
I know what you're trying to say, but what ratrod means to me, (and what I think the word has evolved to mean,) is a patina-finished vehicle or one cobbled up with parts from multiple different vehicles. However, as I understand, it originated from people who wanted a hot rod but didn't have much cash, so they grabbed anything they had, or had to pay very little for, and welded and chopped until it, (kind of,) fit. This usually ended up in a very unsafe car, (think big block on stock model A chassis, steering, and brakes.) This then became popular with the people of slightly more sound mind who wanted that "ratty" look with better build quality and safety. I've seen some "rat-rods" with incredible craftsmanship and ingenuity, and some that scare me to think about being anywhere near while it's driving around.
Update on front suspension
Cutting two inches out of the front cross member to narrow it.
You're right, the Crown Vic cross member is too wide for the F-1 - F-3 trucks. That was a challenge that we were prepared for. We cut two inches out of the center of the cross member, then re-assembled it by TIG welding and adding thick aluminum gussets on all four sides over top of the joint. We also had to design some adapter plates to mount the steering rack, and shorten the tierods by an inch each to compensate for the narrowed track. Now the wheels fit nicely inside the front fenders. Later we'll have to design and build some adapters for the engine mounts as well.
Here's the modified cross member temporarily installed in the truck chassis.
With the front bodywork set in place, the wheels sit nicely inside the fenders. The normal ride height will be an inch or two higher than this.
I should probably clarify my meaning about the term 'rat rod'. The completed project will look like an old, weathered truck. But under the body, everything will be pretty sanitary. The chassis will be fully refurbished and powder coated, as will all the suspension bits. The engine bay will be tidy and freshly painted, and the interior will be completely re-done.
When we got the truck we weren't sure just what direction this project would take, but now that we're three months into it we're getting a clearer picture. We've decided to shorten the box to just over six feet, which will also mean taking a chunk out of the frame. We'll take as much as we can from the back, and the rest from behind the cab. The rear suspension, which is already mostly installed, is an IRS unit from a Lincoln Mark VIII, and we'll be using airbags all around. At this point we're also thinking about a chopped top.
I did say at the start of this that it would be a 'budget' project, and most of these mods involve considerable labor but not much cost.
More updates to follow....
#28
#30
I'm really liking the way it is coming out. Keep up the good work! And keep the photos coming !!
I spent over 25 yrs. working in body shops (retired form that now)and I have No desire to restore or do another fancy paint job. Anybody with money can have a pretty truck. But I love the look of 60 yr old patina. So as many guys here have said RatRod is more about skill than it is about having deep pockets. Unless you pay someone to build your rat rod for you. By the way that is cheating !!
I myself am hoping to find a old 46 Jailbar with original panita to make a rat rod/ survivor type truck. Not a true survivor and not a true rat rod more like a hybrid. I love the old Ford trucks from about '36 to '47 and some of the old IH's myself. I am hoping sometime this summer to have saved up enough cash to find a original panita '36 to '47 Ford 3/4 to 1 ton truck that is unmolested by human hands to start my build. Mine will be diesel powered and modern brakes and the rest I'm going to try to leave alone.
By the way what did you do with that front straight axle from your truck?? Because that is a really cool piece but I understand it didn't fit your plans for your truck. I ask because I know a guy with a F3 looking for parts so what you don't use I might have a buyer for so PM the parts you want to get rid of.
Schuyles
04-30-2013 10:12 AM
