Would you guys go through the trouble of un-skinning these doors to fix them?
Here are the problem areas, I have two extra door tops to cut the pieces from. I am debating on un-skinning them to clean the rust from within the door and under the seams as well. Thought it would make the patch work easier and cleaner as well.
Those pics show how rusty the inners are and the rot areas.
Received 4,135 Likes
on
I know there are perfect rust free doors, cabs, fenders, you name it but for some of us it's just cheaper to repair if time is not an issue. I've had to lift the wrap over and replace rusted metal on my doors. Took a bit of time but satisfying when done. I also replaced the roof section in the drip rails on the cab I'm working on now and should be putting it in primer next week.
on
John,
What does the final product look like?
I guess I am trying to decide where to draw the line. These doors look like the one in the post above, bottoms were gone, and have the exact cancer you replaced. The were blasted previously, and as with blasting there are several places it ate up the rot on the skin flaps. They look like swiss cheese on the back of my door.
Do you leave them alone, paint over? Filler to clean them up? Or cut it out and replace it.
I haven't been to enough "shows" to see what other guys do. Of the shows I have been to it is all or nothing. Seems like they are either show trucks, or amateur work that look like crap........
on
John,
