Fuel tank removal help
An easy job turned into a hard one. Trying to get the fuel tank out of a 47 cab I have for parts. Passenger side seat bracket has some square tab welded in so I can't get the bottom of the seat out. Also, I don't know what this part is, I believe it is what is holding the tank on still. Anyone know what I need to take this out?
I have all the nuts removed and the filler pipe for the tank. I am still hung on something. Is there a bolt and nut under the cab? I try lifting the tank out but it feels like something in the center is holding it on. I am stumped cause this is my "parts" cab and I have no room or way to tip it over and look under it.
Sorry I forgot to post the updates. Got the tank out. Some wrong parts on it made it hard to get off. Plus when I shake it I hear a piece moving in it. Probably a rock or bolt. Needles to say, I don't think I will use it for a spare or backup. I will check the tank on the other truck. If that becomes a problem I may just fabricate a new one in the frame rail.
LittleBlue79
10-27-2017 12:44 PM
z31freakify
11-24-2015 09:17 PM
mark23487
11-23-2015 12:09 PM
lazzarruss
09-23-2015 03:49 AM
