heat problem on my 99 f150
need help i have a 99 f150 i have replaced the heater core thermostat blend door and hoses to the core and still have no heat when i reach into the heat plentum box cold air blows through the ac core and the heater core gets hot but no air blows through the heater core and the only thing that blows out of the vents is cold air and also the blend door is open any help would be greatly appreciated i am freezing in this truck
skip down a couple posts and you can see a drawing of the air flow and doors.
https://www.ford-trucks.com/forums/9...-please-2.html
I had the blend door on my truck do what they normally do so I had it replaced. I found out what broke mine was the actuator. It was worn enough that the part that fits into the blend door wobbled so bad it broke the mating socket on the door. I would suggest if anyone replaces the blend door also replace the actuator. I also suggest that you use a Dorman brand door, they have a reinforcement band on the door socket.
on another note, I had the control arm on the outside air door break on our 2002 EXP several years ago. The door would flop around and cold outside air would drop on the passengers feet in the winter.. I ended up removing the glove box, pushing the door all the way closed and RTV a pop sickle stick as a wedge to keep it closed FOREVER. End of story. No outside air anymore.
superman7928
01-30-2015 03:08 PM
