98 F150 oil in coolant
Old 04-02-2014, 07:38 PM
ehal7's Avatar
ehal7
ehal7 is offline
I noticed this morning there was oil in the coolant reservoir. A repair shop said it was the auxiliary engine oil cooler that went bad. Does this sound right? If so, how hard is it to replace? Thanks!
Old 04-02-2014, 11:02 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
There needs to be reasonable assurance it is the cooler coil first.
Is the oil deposits reddish or blackish?
The coil is put in the end cap and sealed with fittings before is it put on the core.
Either replace the radiator or disconnect and use an Aux cooler.
The difference will be from a cold start the trans will take somewhat longer to heat up before allowing OD to function until the fluid temperature reaches about 98 degrees.
Good luck.
Old 04-03-2014, 06:02 PM
ehal7's Avatar
ehal7
ehal7 is offline
I guess the oil would be more red than black.
Old 12-03-2014, 03:33 PM
73richards250's Avatar
73richards250
73richards250 is offline
did you ever get a conclusion on this subject? Im having the same issue. mine is the 5.4 2v
Old 12-03-2014, 07:37 PM
ehal7's Avatar
ehal7
ehal7 is offline
I never have. I am getting a new engine oil cooler this week. I'm going to put it in, flush the engine and cross my fingers.
Old 12-03-2014, 08:30 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
what is in the coolant ? Motor oil or transmission fluid ? If it is motor oil and it is from the coil in the radiator, just bypass the cooler as mentioned and prove your theory.
FL SuperDuty
12-22-2017 10:29 AM
st8yd
05-26-2015 05:09 PM
stimm32
1999 to 2016 Super Duty
04-12-2013 12:39 PM
Thermo2008
08-14-2011 08:03 AM
moliver7130
05-08-2011 02:08 PM
Quick Reply: 98 F150 oil in coolant
