How to use a Hot Flusher machine on the Torqshift as a fluid exchanger @ SDutyS
Old 11-12-2014, 11:57 AM
creator's Avatar
creator
creator is offline
Anthony's got a hot flusher machine here at SuperDutyService and hasn't had time to figure out how to use it on our trucks as a fluid exchanger. I've been tasked with figuring it out and my truck gets to be the Guinea Pig.
Hot Flusher(the company) says that at the machine Can Not and Should Never be used in-line with the transmission. Especially because of the high pressure reversing flow cycles it does. I can understand if there are any one way valves that this would be a bad idea.
Need input from shops that are using the Hot Flush machine, or Mark Kovalsky.
1. Where it should be connected? (We are thinking post ext filter, right before it hits the cooler)
2. Should the reversing cycles be disabled to mitigate damage to the tranny?
Let's figure this out so Anthony can start doing hot flushes.
Old 11-12-2014, 04:10 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
NEVER reverse flush!
It says to to use it. I think they are right.
Old 11-12-2014, 04:20 PM
creator's Avatar
creator
creator is offline
Thanks Mark.
I know Ford says to use it, or the Rotunda one. Both of the people I talked to at Hot Flusher said not to and seemed to have no idea what I was talking about.
Old 11-12-2014, 07:41 PM
Mark Kovalsky
Ford has a hot flusher for coolers. Is this what he has? If so, they are right, don't connect that to a transmission.
Old 11-12-2014, 07:52 PM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
That is just great they make 2 different machines , now you guys have the added joy of figureing out which machine yall actually have before yall kill something? Hopefully yall kept the paper work somewhere.
Old 11-12-2014, 08:02 PM
MC5C's Avatar
MC5C
MC5C is offline
According to their web page, Hot Flusher makes flushers for oil coolers and heat exhangers, not transmissions. Based on that alone I would not use it on a transmission until I had a documented process and procedure from the company that makes it.
In Japan you get hot flushes on the toilets. You also don't use them on transmissions...
Brian
Old 11-12-2014, 08:06 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
This hot flush machine for the transmission is sorta like Bigfoot or a UFO. We just come "that close" to a verifyable sighting. Lol
Old 11-12-2014, 09:42 PM
creator's Avatar
creator
creator is offline
Old 11-12-2014, 10:00 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Give them a call. They will probably be a help, or able to lead to where you need to go.
Or, take a drive to New Hampton, IA. LOL
Old 11-12-2014, 10:40 PM
04badford's Avatar
04badford
04badford is offline
Old 11-12-2014, 11:01 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
That is a cleaner if a person wanted to clean a cooler without replacing it.
Not a trans flush machine.
Josh
Old 11-13-2014, 03:32 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Josh
Sounds like something that a hydraulic shop would need. Would
rather flush one of those large exchangers Vs replace it.
Sean
Old 11-13-2014, 07:51 AM
Bullitt390's Avatar
Bullitt390
Yep. It's to flush out expensive or inaccessible coolers and heat exchangers.
Josh
Old 11-13-2014, 10:28 AM
creator's Avatar
creator
creator is offline
So who makes the "right" machine that actually heats the fluid, and where are the shops that use it connecting it?
Old 11-13-2014, 11:41 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Well I think that this is almost the same thing you have on your hands now.
https://rotunda.service-solutions.co...?itemID=109966
Sean
Quick Reply: How to use a Hot Flusher machine on the Torqshift as a fluid exchanger @ SDutyS
