Slow Brake Pedal Return
Joe:
I doubt your booster functioning or not has anything to do with your pedal return. There could be some binding in the master cylinder due to debris or a problem in the return springs in the drums (assuming you have drums). You may want to bleed the system and check the condition of the fluid first.
Like resonateur says, check everything because you don't know what someone else did. Watch out for the mickey mouse stuff.
Good luck
andrewscofield
09-11-2019 10:55 AM
hulaman
13
06-24-2016 11:24 AM
reno138
03-13-2014 08:12 AM
