Fuel tank replacement
So, the Ol' 2003 6.0 farm truck needs a fuel tank repair. The tank lining has deteriorated and is causing issues. It has the 40 gallon tank behind the axle (chassis truck) Should I get the tank re-lined or replace it with a Poly tank? Anyone bought a Poly tank and installed it? There is one on eBay for $540.00.
I just replaced my steel tank with a poly tank from eBay last month. Probably the same one you are looking at because the price is the same. It is an exact fit for the old steel tank and it took me about two hours to do the job. One note of caution, make sure the push on fuel line is firmly connected to the fuel sender before bolting the skid plate back up. If it comes loose the truck won't run and it's real hard to reach up in there and reattach it if it comes loose...
That sounds like experience talking LOL. Thanks for the advice. I like the sounds of the poly tank.
Yeah, I was on the road hauling hay and it just shut off, with good IPR pressure. Acted just like it ran out of fuel, except the tank was full. I put a new fuel pump on it and it still wouldn't run, it was pumping air. So I check the connection at the top of the tank and it was loose.
I know that Ford Truck Enthusiasts Forums - View Profile: Super Duty Service was doing something to steel tanks
that he said seemed to be working.
Sean
jake wells
02-16-2011 11:03 PM
johaner78
08-30-2009 08:21 PM
