column shift to floor conversion
Old 11-04-2014, 08:08 PM
52F1Gary's Avatar
52F1Gary
52F1Gary is offline
Does anyone out there have any experience with converting a column shift three speed on a 1951 F1 to a floor shift? This truck has a 6 cylinder engine. When shopping for a transmission, how can I determine it will fit the six cylinder?
Old 11-04-2014, 10:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Welcome to the forum!
The V8 and 6-cyl flathead trannies are the same. You'll be looking for a '48- '50 light duty 3-sp. Be sure to get the sheet metal plate that mounts on the top of the trans, might as well also get the floor panel if you can.
Old 11-05-2014, 07:00 AM
49willard's Avatar
49willard
49willard is offline
Ross, aren't the only pieces required are a transmission case and shift tower from a toploader almost any year from 1933 up to 1950 since the only unique piece for the truck is the gear set and rear transmission mount which bolts to the back of the case which he has with the side loader?
Old 11-05-2014, 09:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, but the shift tower has to include all the shifting forks, too.
Old 11-05-2014, 11:49 AM
52F1Gary's Avatar
52F1Gary
52F1Gary is offline
Thanks guys for your input. Does the engine have to come out to swap the trannies? Can this be done without a lift? This would be something I have not attempted before.
Old 11-07-2014, 06:03 PM
rhopper's Avatar
rhopper
rhopper is offline
I think column shifts are pretty cool, I'd keep it if I were you. Plus, you have a built in anti theft device. How many young punks know how to drive a column shift?
Old 11-07-2014, 06:34 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Why are you looking to make the change?
Old 11-07-2014, 08:21 PM
52F1Gary's Avatar
52F1Gary
52F1Gary is offline
I like the idea of shifting with a floor shift.
51merc
07-23-2008 09:47 AM
51merc
09-22-2007 06:18 AM
black89
11-20-2006 06:24 AM
sancochojoe
04-16-2005 07:54 AM
revinbluejeans
09-02-2003 10:48 AM
Quick Reply: column shift to floor conversion
