Salvage Yard Rear Axle Best Guesses
Alright so per the following thread I have been searching for a 9"
https://www.ford-trucks.com/forums/1...axle-swap.html
I found one at a local pick and pull today and was wondering if you guys could take a look at these pictures and share your knowledge before I pull this.
Alright so a couple more questions. I have studied up a little on open vs locked vs limited slip, and limited slip is what I would be shooting for. I am guessing I can just get a new carrier to put in when I do the gear change right? Also, what about the spline count? should I keep looking for a 31 spline? and how did you guys tell this was 28?
I also notice a slight taper at the end of the axle tubes. What does that mean for bearings, etc.?
This would be donor vehicle is a Super Cab and I have a Regular Cab both have 8ft beds. Should I be concerned about pinion angle or would the difference be negligble?
Should I care about any of this or am I over analyzing?
I'm not in a super hurry so I can pass this one up if I should keep looking.
Thanks for the Info!
I dunno how the others knew the axles shafts have 28 splines, but here's the info from the parts catalog:
D8TZ-4234-E .. Axle Shaft-28 splines - Use with AXLE ID tag codes WDM-CJ & CL
Left (column right): D8TZ-4234-E listed in parts list 91 / Right: Look at the 5th listing from the bottom for D8TZ-4234-E's spline count.
Thanks Bill. I see where the "WDM-CJ" is on the tag now, and how you've made the connection between the two pages. I have a parts catalog on CD but an still learning to use it. To that end... I also see there that "WDM-CJ" is listed below on D6TZ-4234-C. What makes this the D8... vs the D6...?
Ridiculous!
swampape
03-19-2011 03:11 PM
