240 Oil Pan Gasket Replacement
Can you remove the oil pan without having to lift the engine?
My front cover gasket set came in but, the front pan seal overlaps back into the front corners of the pan/bottom of the engine pan rails by about 1" on each side. The ends of the seal won't go in unless the pan is loosened and dropped down. If I have to break the pan gasket loose to do this, it's likely to leak worse if the pan gaskets aren't replaced.
I've gotten some of the oil leaks stopped but, my 240 still leaks oil like the Exxon Valdez.
I figure now is a good time to remedy some of the remaining leaks, since I don't want all my pretty new suspension and brake parts getting coated but, I'm not sure if I can remove the pan without having to lift the engine off the mounts (?).
Just about every set comes like that I've seen no mater what type 6 or V8's.
This is incase the gasket tears some. Cut it and butt it up to the pan gasket.
Clean it well and put a bead of rtv let it skin over a little install front cover is how I've always done it never leaked
Orich
Orich
I just don't know if the oil pan will come out without having to lift the engine?
--aside from being really oily and dirty, the paint looks really bad on the pan. It needs a good cleaning, bead blasting and a new coat of Ford blue paint.
Jolly Roger Joe
34
03-06-2017 01:04 AM
Dorsai
15
06-17-2012 05:56 PM
