Question on vacuum modulator
My transmission was rebuilt completely in January and by a very good mechanic. So this morning I noticed the transmission shifting weird when warmed up. When going from 1-2, it jerks back and forth like it doesnt know which gear to go in, then seems to jump to third. when I manually shift the truck, all is just fine. I noticed the idle to be a little higher and rough as well (vacuum leak?). When I squeezed the vacuum line going down to the modulator, the idle smoothed out.
Back in January, the mechanic did not replace the modulator valve - I had put one on a few years ago and told him not to do it.
Can the modulator be the cause of this?
Found it. It was the small piece of vacuum line that connects the hard line to the modulator nipple. The intake manifold leaks so bad that it had softened / swelled the hose.
So another question - this has been this way (I think) since I got it rebuilt and am just figuring this out. My truck actually misses second gear. It goes from 1 to 3. If I manual shift, from 1-2-3, all gears are just fine.
Would any adjustment in the modulator valve allow for this, or is this more of a transmission band adjustment?
Jemo1stford
27
02-18-2015 11:36 AM
alchemist1
10-24-2014 02:51 PM
F550Dreamer
09-21-2008 06:30 AM
pedrorairez
03-12-2007 12:43 PM
