445 build
#91
on
I didn't get a part number, I'm getting a rotating assembly, heads, cam, and lifters, just asked him to add it in. He did tell me it was a Crane part for the .467 distributor shaft.
Since he is incredibly difficult to reach I don't think I'll have any more info until the parts show up.
I did find this after a few searches:
COMP Cams - Performance Camshafts, Lifters, Valve Springs, Rocker Arms
#92
I sure hope so! Although not much more $$ than a holley. I do not really care for the silver color on the QF but its all about how it works and adjustability
#93
Here is a steel one made by Mallory Ignition
http://www.summitracing.com/parts/ma...FYWVfgodkS0A7w
Here is steel gear by crane cams 34970-1
http://www.summitracing.com/parts/cr...view/make/ford
#94
#95
#96
I have a drawer full of the brass.
I ended up buying the Crane gear the week before I was ready to start it. The day I wanted to start it was the day I realized the distributor would need re drilled for the new gear. Somehow I completely overlooked that important detail. I never realized the hole were off center from the factory. Whoops
#100
Sorry that's all I've got for now. I need to do a couple things to it here when I get a chance. It's just been sitting with my work schedule. Good thing about working 60 hr weeks I feel like spending some money!
I need to buy another harmonic balancer, from what I can see this one slipped. My timing keeps changing without me. I knew better too but what can I say. I also need to go over the valves one more time. I'm also contemplating switching distributors along with buying a wideband kit.
#101
#102
on
Getting a little deep in the fall here for this, but I've finally got almost all the parts I need to start putting my 445 together. Got the cam in today but realized I don't have the Woodruff keys, so need to find some on Monday. Did a trial fit on the rest of the top end to make sure the T&D rockers will work under my valve covers, make sure my pushrod length checker is the right length etc.
The BBM heads intake ports are a perfect fit to the gaskets, so easy to mark the intake for port matching. Got that done today, I'll take the intake to the machine shop when I pick up the keys and get him to toss it in his jet wash. Then I can put it together, get it in the truck, and fire it!
#103
You're getting down to the exciting part. I love hearing something run for the first time. I'd say you won't be disappointed with yours it looks like you did all your homework. I'm kinda going through building withdrawal I think. Tomorrow I plan on tearing down a 460 I have sitting around and starting another build for another truck. It's not going to be near as elaborate as this one but more something to do.
#104
on
My buddy, the fellow in the picture setting up the dial gauge, built a 521 based on a 460 for his 67 F100.
I wanted to stay with an FE, not the least because it is a 4WD and there is a bunch more work getting the driveline together with an engine swap.
His is a rocket. Probably making in the 600-700 hp range.
Fellenz
02-06-2015 08:58 AM
1976 drag
27
08-27-2004 10:56 PM
AceTrucking
16
04-05-2004 02:40 PM
1976 ranger
02-11-2004 03:00 AM
