TS Chip not programmed correctly?
Gearhead tunes on my SD drive like a stock truck at the top half of the pedal. Once you get to half throttle, things start coming to life. The race tune is even extremely controllable in the smoke department. It will smoke if I purposely get on it under the turbo, but no big deal. Drive like a normal person and it drives normal. The power is there too. I have Tony Wildman and Gearhead tunes on that truck and Tony's stuff feels a little more potent, but they smoke way more. I still like the feel of Tony's tunes and usually find myself using his tunes, but when I get into town where I need no smoke and still want good power, I switch to Gearhead every time.
Glenn or Travis, how exactly does stacking work? Is one more fuel related and the other timing? I googled it but eh, I figured I'd just ask if the OP doesn't mind..
No this is all good info and is good to have all in one thread. My main goal is to see how many tuners there are out there to look into. Since BTS doesn't do it anymore I guess.and Tony Wildman was the only other one I knew of really. I'd like to have someone live tune it but idk if I got anyone around KC that does
You don't "stack" chips on a 7.3. In the Dodge world they stack tuners and modules. When they do it, they are using a pressure box with a separate tuner for timing and other stuff.
I run a Hydra chip, so I can burn my chip with tunes emailed to me by my tuners. They are separate tunes, just like your TS. I just have 10 different tunes. 6 from Tony and 4 from Matt.
Jackdaniels97
06-05-2017 08:02 PM
Canadian7.3
02-18-2014 09:08 AM
shanett306
01-27-2009 07:51 PM
