Little Bit-O-Progress
Old 10-10-2014, 07:36 PM
eman92082's Avatar
eman92082
eman92082 is offline
Haven't posted much lately. Just watching and an occasional smart-a$$ comment to add to the levity...
Here's a few shots from this last weekend. As I get ready to install the front-clip, I question why there isn't some sort of rubber pad between the radiator support and the frame? I'm going to be using a Dodge Truck radiator hard-mounted between the support.
No rubber pad ? - Really ? '49 F1
Old 10-10-2014, 08:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Yes, there is one, manual says to use a piece of tire carcass for replacements. (#8124 below)
Old 10-10-2014, 08:39 PM
eman92082's Avatar
eman92082
Makes sense - Thanks. Guess I was looking in the wrong page. I noted that the other years showed them in the exploded view. I think I even looked for them in various catalogs and while they were listed for 51s etc., I found nothing for '48-'49 as I recall.
I suppose the springs and such are essential as well. I'll investigate.
E-Dawgie
Old 10-10-2014, 08:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check this thread: https://www.ford-trucks.com/forums/1...l#post14196807
For many years the bolts and springs were not available, people just used carriage bolts and old valve springs, but it appears they are available now.
Here's a thread with specs for the springs and bolts if you want to DIY (I probably would). https://www.ford-trucks.com/forums/4...a-48-52-a.html
Old 10-10-2014, 09:38 PM
eman92082's Avatar
eman92082
Much Appreciated
Old 10-11-2014, 10:23 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
Been trying to find a replacement radiator for my 56. What Dodge radiator are you using?
Old 10-13-2014, 12:06 PM
eman92082's Avatar
eman92082
Sorry for the delay. The part number to fit my '49 is likely not appropriate for a '56. I suggest you open a thread asking what others are using on '56s. There must be a gazillion folks that can provide real-world advice.
Check the US Radiator web-site. The on-line catalog provides dimensions. Once I nailed down the exact year/model, I then shopped a regular OEM radiator source as the prices are half the cost of the custom outfits.
Good Luck,
Dawgie
Old 10-13-2014, 02:48 PM
bjmayberry2
Thanks Dawgie. I've heard of guys using a Dodge Radiator on the 53-56 F100s and thought maybe yours was the one.
Marauder2004
01-13-2019 10:57 AM
oscajo
03-08-2015 02:13 PM
tomrflorida
03-25-2014 06:09 AM
oscajo
07-04-2013 07:18 AM
ct50f1
16
05-16-2013 07:24 PM
Quick Reply: Little Bit-O-Progress
