HOW TO: Swap AMP meter to VOLT meter
Old 11-13-2021, 07:27 PM
JimsRebel's Avatar
JimsRebel
JimsRebel is online now
Originally Posted by Dipstik86
Attempted to wire my ammeter like described and when I hit the key the gauge went all the way to the left and then popped back to center and the gauge started smoking. What did I do wrong? Yellow to ground and the red to a keyed 12v.
In post 4 you will see a photo of the Rocketman volt meter. Notice where the needle is, at the far left, not in the center position. An Amp meter will have the needle in the center position at rest, meaning no power - key OFF. Based on what you describe above it would seem you installed a Amp meter, which is why the needle is spring loaded to the center position.
Jim
Old 11-14-2021, 02:04 PM
Dipstik86's Avatar
Dipstik86
Dipstik86 is offline
My excitement got the better of me. I had 2 gauges and I grabbed the wrong one and installed it. My bad 👎
Nigel Anderson
02-23-2016 11:24 PM
barljos13
01-17-2011 06:49 AM
1yamman350
02-27-2004 02:50 PM
Marc150
02-03-2004 07:48 PM
bcf
Electrical Systems/Wiring
11-05-2003 06:41 PM
Quick Reply: HOW TO: Swap AMP meter to VOLT meter
