Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2009-2012 Ford Escape No Start Theft Light Flashing Diagnostic Walkthrough
Old 10-03-2014, 02:02 PM
makuloco2000's Avatar
makuloco2000
makuloco2000 is offline
This one here is a real good example of what we are seeing at the dealership and what to look out for. In this video I walk you through diagnosing why you theft light is on and why the pcm is not powering up.
Old 10-03-2014, 09:15 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Good job! I'd rep ya if I could
Old 11-14-2014, 09:21 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
So if you have to change one out do you need to have it programmed? Or is it plug in and your done?
Old 02-22-2019, 02:48 PM
Sliprock's Avatar
Sliprock
Sliprock is offline
PLEASE help looking for PÄTS CODE 13
I turned my Escape of its a 2003 xlt 6 cly 4x4 I only have one key I drove to the store turned it off went to go back out no start no turn over the anti theft light blinks fast then stopped and blinked once then three more times guess code 13 can anyone please tell me what I should and can do to fix this myself thank you I need help I’m stuck
Old 02-22-2019, 10:21 PM
simonsi's Avatar
simonsi
simonsi is offline
I think it will be DTC03 for the PATS system, the limited documentation I have indicates: "ID number is not input into immobilizer unit after ignition switch is turned to ON position or cranking engine."
Look here: PATS Info
Old 10-04-2022, 11:44 AM
Koolminx's Avatar
Koolminx
Koolminx is offline
EDIT: I did follow this video and verify all grounds and powers were as necessary as per his direction.
2012 Escape, 4 cylinder 46K original miles in incredible physical condition. Sat for about a year, battery dead. Replaced battery, PATS system activated, rapid flashing with key in ON position.
Same with Either Key. Batteries replaced in both keys. Reset PATS by disconnecting new battery, turning key to ON position, hooking up battery, waiting until flashing PATS went off, turned key off, then turned key on and started. This worked and the car started with both keys.
After about an hour, the Pats would activate again with either key it would not recognize.
So I figured it the PATS transceiver around the ignition switch forgetting the RF of the key. So $63 dollars and 15 minutes of work later, there's a new transceiver and after the process resetting started again. After one hour the pats activated again.
Another of her friends Sent the ECM/PCM to New York, had it inspected and apparently re flashed. Reinstalled, the keys both worked, start and run shut off over and over, but after an hour the PATS activated again because SOMETHING in the system is forgetting the RF signal between the key and the Pats, even though the key and fob both work to lock and unlock the vehicle physically and remotely and operate the ignition perfectly. Remember there's very low miles on this vehicle.
So are there any thoughts on the PATS forgetting the key's RF signal after an hour and needing resetting before I haul it to the dealership and force her to spend $155 bucks for the diagnosis alone?
Thanks folks, I look forward to your thoughts and questions and suggestions.
Regards
Gary
AzPete
13
11-21-2012 04:58 PM
blue1ton
05-29-2012 04:31 PM
chizetown
1999 to 2016 Super Duty
04-28-2010 02:32 PM
Quick Reply: 2009-2012 Ford Escape No Start Theft Light Flashing Diagnostic Walkthrough
