HELP ! need original part numbers...
hi,
.........in taking a part my clutch release arm to replace bushing, I have naturally found that I will also need the clutch equalizer ball bracket, washer and spring.............
in contacting dennis carpenter, the ball bracket is out of stock.........in contacting their supplier, they are also out of stock and have no leads as to where to find them..........
.......I was referred to a ford dealer who has some of these old parts, they have the bushings in bronze !, but need original part numbers to see if they have the:
-clutch equalizer ball bracket and,
-the washer for this bracket, and
-spring........ THANKS !
Better yet, spend the $20 for a Parts Manual on CD, and $25 or so for the factory manual. You could have your answer immediately.
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
thanks for your responses..........
1950 f1 239ci flathead v8....
.....thanks for your suggestion regarding cd and manual......had bought the ford f-series trucks shop manual (licensed reproduction) when I purchased the truck a couple of months ago...........
..........however the linkage assembly pictured for illustration is for the f7 and f8 trucks and the assembly is not the same for my f1........
chrislynn5
45
06-20-2016 08:42 PM
ddiaz12
01-12-2016 06:18 PM
Jprokusek
01-24-2014 01:06 PM
tonygray
03-04-2008 04:58 AM
Ol Rudy
15
01-07-2005 08:11 AM
