Rancho's RS9000XL adjust. knobs protection
Another thing to consider, we do add a coat to protect the shocks but I would hit them again with an additional clear coat. I hear that the Canadians like to salt their roads a lot in the winter.
This
Ant this.
When I installed mine, I put the adjustment **** in between the plates of the lower mount, facing the axle. It makes it a little harder to access, but does provide some level of protection. My truck is 2003, so I don't know if they have changed the mounts on newer trucks.
Ant this.
So glad I changed my mind at the last minute and went with the Ranchos instead of Bilsteins!
I'm not sure the spring rating on the newer Super Duties but the camper package I would imagine would be stiff unloaded. That being said, my old leaf spring dinosaur is not a soft ride but there is a noticeable ride difference between the soft (1) setting and hard (9) setting.
That's my thinking as well. I'm hoping to replace the tires and shocks and maybe soften the ride some. We like to explore off road and the current set up is just to stiff, causing the rear end to bounce so much you feel like your on the verge of being out of control even at very slow speeds.
weigh your truck,
find out the MINIMUM pressure you need to support the weight from your tires load inflation charts
and that will help...
for MY truck and tire example:
PSI . Max weight
35 . 2,080
40 . 2,280
45 . 2,475
50 . 2,680
55 . 2,850
60 . 3,030
65 . 3,195
70 . 3,375
75 . 3,540
80 . 3,750
so,
with about
50 PSI front = 2680 x 2 = 5360 lbs for front axle
and
65 PSI rear = 3195 x 2 = 6390 lbs for rear axle
5260+6390 = 11650 lbs for the 4 tire ratings
That might be enough for your TOWING weight, much less empty weight if you don't overload your pickup.
That's enough for my 11,500 GVWR.
And if you have more than 11,500 pounds on the 4 tires of an F-350 SRW, you're overloaded.
Now I normally run about 60 psi front and 70 psi rear so my tpms doesn't yell at me, but your truck has different specs, so go weigh it http://catscale.com/cat-scale-locator
80 psi rear is insane on an empty PSD.
PSI . Max weight
35 . 2,080
40 . 2,280
45 . 2,475
50 . 2,680
55 . 2,850
60 . 3,030
65 . 3,195
70 . 3,375
75 . 3,540
80 . 3,750
so,
with about
and
z1121jack
04-28-2008 05:31 PM
