Stock the wastegate is set at 7.5-9psi. you can turn your pump up for sure if its in good shape. Do a search on adjusting the wastegate rod. You have to drill something otherwiese you will twist the rod off. Turn up pump, set timing to 7* make sure pyro is installed and enjoy
