Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Transfer case for a T-19
Old 03-23-2015, 08:29 PM
03-7.3L's Avatar
03-7.3L
03-7.3L is offline
Hey Guys , I'm looking into installing a transfer case on a T-19 Tranny behind a 6.9 L . It's a 2WD but I need the low range . Any thoughts on the best transfer case that bolts up . Tks
Old 03-23-2015, 09:12 PM
fordman75's Avatar
fordman75
fordman75 is offline
I'm planning the same basic deal in a 2wd E350 van that I'm swapping in a NP435 4spd.
I don't know what age truck you are dealing with. If the 6.9L is stock I am guessing mid to late 80's. For all out toughness I would go with the one I'm going to use, the NP205. It's a cast iron all gear driven unit. It's nearly bullet proof. The down side is the low range isn't super low.
I believe the transfer case that came in the 6.9L 4x4 trucks would be the aluminum case, chain driven BW-1345. Not as strong as the NP205 but it has a lower low range.
Old 03-25-2015, 07:12 PM
03-7.3L's Avatar
03-7.3L
03-7.3L is offline
It's an '86 . Thought the 205 was the way to go , just curious what combinations people liked . Tks Ted
Old 03-25-2015, 08:00 PM
fordman75's Avatar
fordman75
No problem.
The NP205 will require some kind of side support/mount due to it's weight. On my van I'm going to fabricate a custom transmission cross member and tie it into the cross member.
You don't really have to worry about that with the aluminum cases. But I think the 205's strength and durability makes up for any extra fab work.
Old 03-25-2015, 08:30 PM
03-7.3L's Avatar
03-7.3L
03-7.3L is offline
Absolutely . Cheap piece of mind
SuperBerry111
08-17-2011 07:02 PM
77custom408
09-10-2008 10:52 AM
jmnt919
01-10-2006 09:38 PM
DW2455
1978 - 1996 Big Bronco
04-30-2004 04:06 PM
2Wise4aGM
05-14-2002 02:53 AM
Quick Reply: Transfer case for a T-19
