Zf-5speed oil
Old 09-18-2014, 10:19 AM
pwjackson42's Avatar
pwjackson42
pwjackson42 is offline
Looks like it is only available in Switzerland. Says it is a 75W80 oil, I bet it is just synthetic 75W80 gear oil.
Old 09-18-2014, 10:21 AM
pwjackson42
Here is the link to the ZF fluid data sheet
https://www.zf.com/na/content/media/...Data_Sheet.pdf
Old 09-18-2014, 12:35 PM
dieselsubmariner's Avatar
dieselsubmariner
dieselsubmariner is offline
Thanks for the cut sheet for the oil. It indeed looks like 75w-80 synthetic . I know redline makes some ..
I checked on that zf oil and can't find it ..
Old 09-18-2014, 12:50 PM
glovemeister's Avatar
glovemeister
glovemeister is offline
I'm gonna try Redline MTF on the next fill up.
Old 09-18-2014, 04:54 PM
richdawg's Avatar
richdawg
richdawg is offline
I used the D4 ATF, it was what the local distributor recommended. I put in four quarts and didn't see much improvement in the shifting or gear rollover, so i added the other quart. I have had no problems with the overfill and really haven't had the improvement in rollover noise i was hoping for.
Maybe you will have better results with the MTF
Old 09-18-2014, 05:41 PM
glovemeister
Appreciate the post. Near as I can tell everyone suggests the MTF. I know these trans call for Syn atf from factory. However, Syn ATF isn't helping me with synchro issues. Worst I can do is try it to stave off a rebuild for a bit.
Old 09-18-2014, 05:54 PM
dieselsubmariner
I'm gonna check a couple semi truck places tomorrow, but if I can't find anything I might just try the redline mtl as well. Looking at the specifications of the redline, it is close to the zf fluid, which was recommended to be best by zf.
Old 09-18-2014, 07:14 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I am another one that Redline did NOTHING for other than lighten my wallet.
A $450 REBUILD fixed it though
Old 09-21-2014, 12:26 AM
rcorell's Avatar
rcorell
rcorell is offline
what is gear roll over, is that the horrible sound these 5 speeds make when taking off from a stop?
Old 09-21-2014, 12:47 AM
coreyallan01's Avatar
coreyallan01
coreyallan01 is offline
The sound of gear mesh when you do a SMF (single mass flywheel) conversion; usually more audible in lower gears at slower speeds..
leonharu
03-19-2008 03:15 PM
stevegold1958
04-29-2007 10:57 PM
desert sled
01-30-2006 03:10 PM
Boy Woofer
01-27-2005 06:52 AM
sdrobish
04-16-2002 03:41 PM
Quick Reply: Zf-5speed oil
