65 f100 body on a 78 f150 chasis?
Im a total noob to this truck restoration "disease" so please feel free to laugh out loud at this query...but I think it's worth asking anyway...
It occurs to me that it might be easier to just put the 65 cab and bed on a good solid late 70s chasis that already has the power steering, disc brakes and 300-6 that I want...Rather than scrounge up the pieces and beat them into place on the old 65.
I know there are probably some frame dimension issues but is this a valid approach to modernizing the old ride?
Thanks guys for those bits of wisdom. I have spent the summer thinking about what I want to end up with in this truck. I first wanted to keep it all original. And still like that idea. But I didnt get it to look at or show...I got it to drive. And I have been driving it a bit - at least enough to appreciate the added safety and drivability of power disc brakes and power steering. So Ive convinced myself to try and do those mods in the name of safety. And...to help keep Mrs. Nehi on board with the project (she's not loving the hard steering, brake stomping workout).
+2 on Garbz with 1 word added "bed" so the bed mounts will have to be moved. There is 4in added to the back of the cab & behind the rear mount starting in 73.
Not seen anyone yet do it without removing the hood, but if you lift the cab & front clip together, roll one chassis out and the other back under you wont have to re-align the fenders. The rear wheel appearance in the opening will be different. BUT, this is very doable.
1st check with Alaska DMV to see what is required to swap the VIN. The go to VIN is stamped on top of the passenger side in two places. NC told me that we could attach a NC VIN.
John
John
Yep...as mentioned no matter what approach you take when you move away from the stock configuration you are modifying something. If I put later model axles in my 64 to gain disc brakes and possibly power steering plus go from 4:56 to 3:73, I think the axle tubes and axles would need shortening, steering box and column / shaft mod, etc. Or I could have put my 64 on a later model 4x4 frame but then...the snowball starts when you head away from stock config...have fun!
Like they said above. Mounts up fine until you get to the back of cab area since they added 2" I believe? To the 73-79 cabs. You will have to play with the wheelbase if you want to keep the right gap from cab to bed as factory and have the rear wheels centered in the bed wheel well
John
mulewrangler
06-29-2009 07:08 AM
Andy63
03-21-2003 08:35 AM
