5.4 engine cranks, won't fire........
2005......125K miles
If it sits for a week, it won't fire unless I turn key on and off 2 or 3 times...
I have been living with this until yesterday. Now it can have the same symptoms after sitting 1 hour. It usually runs fine once it starts, but occasionally it will falter and run rough for a while....
A breakdown on the road would be ugly....
Needing your thoughts and what worst case scenario can be........
Thanks.
Thanks.
I have to second this. The easiest way to test it is just turn the key to the "ON" position and listen for the pump to pressurize the line. If it's not humming and you're having to "bump" it 2-3 times to get it to go that could be it. We need a little more info to really help though. Does it crank and not fire? Does it fire but not crank reliably? The first step is to determine if it’s a spark, fuel, or compression problem.
