Need some tailgate handle (replacement) help.
Old 09-09-2014, 07:17 PM
bowtieman55's Avatar
bowtieman55
bowtieman55 is offline
Since I got a box of parts from Rock Auto today, I PROMISE, that after this is fixed, I will finally start a "build" thread...BIG thanks, in advance.
PLEASE tell me what could be wrong here. New replacement tailgate handle, other parts are original.
Looking up into the tailgate
Too much spring extension causing these pieces to NOT work together properly
Tailgate handle, while not operational, sticking out too far. It can be pushed in, but still no worky
When pushed in, these parts don't work together as designed
Old 09-09-2014, 07:19 PM
bowtieman55
Now that I look at it, I'm thinking maybe I should have made sure that the handle was in the "closed" position while connecting the driver's side rod????
Old 09-09-2014, 08:00 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Made in Taiwan is part of the problem.
But it looks like the handle was in the open position but the latch was in the closed position
Old 09-09-2014, 09:42 PM
bowtieman55
I agree about the "Made in Taiwan" part, but it is a project with a VERY small budget. I'm usually quite particular about such things.
The latch; how can I be sure it is in the closed position, or can I just disconnect the rods, "close" the handle, and reconnect the rods?
Old 09-10-2014, 04:46 AM
Diesel_Brad
The handle pulls on those round "cams" Right now they are nOT. So they need to be on the other side
Old 09-10-2014, 07:18 AM
bowtieman55
Does the tailgate need to be closed shut when I am installing the rods; that way the latch springs are pushed in?
I've found this video to be pretty good help.
Old 09-10-2014, 08:06 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,682 Likes on 1,359 Posts
You should be able to take the handle out, clamp it in a vise, and get it figured out by working it like that. That's the way I usually fix the original handles, by bending them back the way they are supposed to be and welding any cracks.
Old 09-10-2014, 11:24 AM
KsCop's Avatar
KsCop
KsCop is offline
I realize budget, but some parts are worth paying the price for.
I bought the 'inexpensive' tailgate latch handle and struggled with it, like you are, for quite a while. I tried bending, modifying, and even welded up an area that kept slipping.
I finally broke down and bought a NOS part. Popped right in and worked flawless.
A 15 minute job with the right parts. A three week disaster with the chinese version.
For me, it was worth the NOS part. It cost me about $40
Old 09-10-2014, 12:58 PM
bowtieman55
I appreciate all the input. I'll see what this evening brings and we'll go from there. Thanks
Old 09-11-2014, 09:04 AM
bowtieman55
Exclamation
As it turns out, the new chrome Made in Taiwan tailgate handle isn't worth a #?*!.
I took the original handle, freed it up, lubed it up, stole the spring from the new handle and used it. Tailgate operation is now a one-finger job.
HOWEVER, it looks like crap...lol
Old 09-11-2014, 10:47 AM
Franklin2's Avatar
Franklin2
Can't help you on the chrome part, but it's crooked, probably because part of it is bent. Usually it's easily straightened if you take it back apart and mess with it in the vise again.
Old 09-11-2014, 11:26 AM
bowtieman55
Fortunately (for me and probably the part, too lol) I didn't have to put it in the vise. I guess I could take it and compare it to the Taiwanese handle and see what the differences are. Worst part is that the Taiwanese one looked crooked like that when bolted up...
Old 09-11-2014, 11:43 AM
SVTDriver97's Avatar
SVTDriver97
SVTDriver97 is offline
That's nothing a little water and quad-ott steel wool can't fix
Red Devil 0320 8-Pack Steel Wool, 0000 Super Fine - Amazon.com Red Devil 0320 8-Pack Steel Wool, 0000 Super Fine - Amazon.com
Quad ott steel wool on chrome shines up bumpers like new in no time! I use it all the time when I have some polishing/rust removal to do.
Eco Catherine
1999 to 2016 Super Duty
08-09-2019 11:04 PM
Don52M3
04-21-2019 02:34 PM
Ben Samways
05-22-2018 03:47 PM
D & D
05-05-2015 09:54 AM
sum_weirdo
02-22-2013 08:29 AM
Quick Reply: Need some tailgate handle (replacement) help.
