Sponsored by: Real Truck
Trouble fitting tailgate
Old Aug 9, 2019 | 03:49 PM
Eco Catherine's Avatar
Eco Catherine
Hello all,
I recently bought this 5th wheel tailgate, pre-used. It fitted onto the brackets just fine but when I went to close it up, it wouldn't connect up properly on both sides. It closes on the passenger side but not on the drivers side.
Is there anything I can do to fix this?
Thanks!
Old Aug 9, 2019 | 07:54 PM
jetjockey99's Avatar
jetjockey99
looks to me like it is manufactured out of spec. I would return it and get a replacement. You could measure both sides from the pivot to the latches to make sure, they should be the same. I don't believe there is enough adjustment in the striker bolts to make it work.
Old Aug 9, 2019 | 08:55 PM
Eco Catherine
I think you are right about it being manufactured out of spec! I have taken your advice and contacted the manufacturer - just not sure if they will do anything as I bought it 2nd hand. They do seem to be out when I measure. My alternative solution is to use some sheet metal and maybe some rivnuts and just move the latch up on the tailgate.
Old Aug 9, 2019 | 11:04 PM
Colorado350's Avatar
Colorado350
Welcome to FTE.
@Eco Catherine The striker bolts are adjustable,up/down, in/out, just loosen them up and move them a bit, snug and see if the tailgate closes. If you get lucky, tighten firmly and enjoy your new tailgate. The tailgate mechanism may also have some adjustments.
