Weld-in Oil Dipstick Adapter Mod
Received 3,697 Likes
on
looks like a good idea.
the only problem I could see is that the pan started out as a flat sheet of tin and than was pressed into it's current shape, there is a lot of stress in the grain of the steel when it is pressed that far, (that is one of the reasons they corrode so bad) when steel that is stressed that much in the manufacturing process is welded the welding changes the molecular lineup and makes stress risers which lead to cracks along the weld.
only time will tell if that will happen.
if mine was leaking I would definitely be doing the same thing but I would do it installed in the truck!
The strictly diesel adapter just seems way too expensive. I don't se why one couldn't take an adapter like you made, drill a hole on either side, counter bore for o-ring or copper washer/seal, then make a bracket that will slide into the pan; cut a felt gasket to go between the pan and adapter and done! If you don't like the idea of leaving the stock adapter inside the pan, make the new one oversized and cut the hole in the pan larger to pull it out. The danger here is getting metal shavings in the pan.
I don't care for that idea either, but that is what the $$$ strictly diesel kit requires. You could probably attach it to the new adapter bracket with some small cable/chain. But this is all a moot point since you have the best possible solution. Just thinking out loud for those who aren't lucky enough to have the engine on a stand.
Bringing this back from the dead. Is there any reason the stock dipstick adapter can't be welded to the oil pan on the inside? I have to pull the pan anyways, would like to permanently fix this problem if it's possible to just weld up what's there without making a new adapter.
The following users liked this post:
Baddhabit
06-11-2016 08:56 AM
tstorm
03-20-2011 11:07 AM
tealboy1
12-22-2009 10:54 AM
