2wd truck in winter weather?
Old 09-02-2014, 05:05 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Originally Posted by Diesel_Brad
2wd with 6" of snow. Just have to know how to drive
^^ This. 4wd gets you stuck further in, and also inspires a dangerous level of confidence in inexperienced drivers.
I've had three OBS trucks: a 96 4.9L 5-speed 2wd with a limited slip diff, a 93 5.0 E4OD 4wd with an open rear, and my current 95 5.8 E4OD 4wd with a limited slip diff. Never got stuck with the 96, and the only time I've used 4wd in the others was either to pull someone else out of a stuck situation, or when driving on the beach.
Weight in the bed, common sense, and you'll be fine.
  #32
Old 09-02-2014, 05:22 PM
GNR22's Avatar
GNR22
GNR22 is offline
Fabri-cobbler
Like Krooser, I'm not a stranger to snow here in WI. The only time I put my truck in 4x4 in the snow is to pull people out of the ditch, and even then, I don't always have to do that.
Driving in snow in 2wd is not a secret. No quick jabs at a pedal, and take it slow. Don't turn too fast, and pay attention if you start to lose grip.
  #33
Old 09-02-2014, 07:02 PM
mefast's Avatar
mefast
mefast is offline
Originally Posted by Shadow944795
I was gonna go ask a junkyard tommorow if they had some cheap rims in my lug pattern I could use and then sometime soon buy the tires I desire, also I'm loving all the inflow of good information on this thread please by all means keep it coming I'm almost at the point of taking notes .
Junkyard rims will work. I wouldn't recommend tires from the junkyard, but to each their own.
This would be the place to take notes from if any. Although those notes are useless if you don't know how to apply the skills when you're behind the wheel. Get comfortable, yet cautious, driving in bad weather and you'll do just fine.
  #34
Old 09-02-2014, 07:06 PM
Shadow944795's Avatar
Shadow944795
Shadow944795 is offline
Oh yeah I wouldn't dare touch a junkyard tire with a ten foot pole let alone trust it on a offroad car. brand new tires will go on the rims I just don't wanna pay a small fortune on rims that will get swapped off every spring for my A/t tires.
  #35
Old 09-02-2014, 09:43 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
i dunno about some of you guys.i hate 2wd trucks in summer lmao.it's an adjustment (and not a pleasant one as far as lack of t-case and traction goes) getting used to my new f450 2wd.....not cool.........in snow........forgetaboutit.wouldn't even bother trying.of course duallies float so bad making them far worse than srw i know,but oh man.i don't miss my 2wd pickups of yesteryear either.
  #36
Old 09-03-2014, 05:31 AM
Pit Crew's Avatar
Pit Crew
Pit Crew is offline
Lots of people have already said put some weight in the bed. But not a few sand bags. Your truck dosen`t even know they are back there. Put some real weight back.1000lbs or better. Start with the cap you mentioned and go from there. I plow snow here in ohio, I`ve had ladder racks, top of the bed tool boxes down each side full of tools and few more hundred lbs of mis. Stuff in the bed and did most of my parking lot plowing in two wheel drive. Weight is where its at, and of course good tires.
  #37
Old 09-03-2014, 06:05 PM
Shadow944795
Yeah i figure I put the cap on there get a good set of tires (thinking going with 31 inch tires just for more ground clearance at the cost of a incorrect speedo) and store everything I need in the tops two tool box things that it has in it already and shove whatever else I think is needed in the bed without worry of it being burred and frozen in snow and ice.
TechJoe
2004 - 2008 F150
04-25-2016 12:04 PM
troverman
1999 to 2016 Super Duty
20
11-30-2013 10:06 AM
landcruzr
01-13-2009 09:58 AM
mgdemarco
General Automotive Discussion
55
09-04-2005 01:35 AM
mjbesen310
2004 - 2008 F150
01-09-2005 10:30 AM
Quick Reply: 2wd truck in winter weather?
