Hit trany coolan line with sawzall, patched it now tranny hesitating and slipping. HE
Old 08-30-2014, 06:42 PM
tunnelrat92's Avatar
tunnelrat92
tunnelrat92 is offline
Just like the title says, putting the stack on. 210k single cab 4x4 1995 f350 no mods. Tranny had no problems prior. Hesitates going into drive and reverse. Slips in first. How screwed am I? I cut out the hole in the hard line and patched it with some heavy duty hose that was a little bigger than the line and clamped it tight. If there's a way to add pictures please let me know. Drove about 6 miles with the hole until someone at the red light told me I was pissing trany fluid. What do you guys think?
Old 08-30-2014, 06:49 PM
fordpride's Avatar
fordpride
fordpride is offline
I don't think that can cause your problems. I'd start looking for cut wires
Old 08-30-2014, 06:52 PM
tunnelrat92
I had to drive to work for about a week with the tow wall light flashing, Im pretty sure that's a heat issue right? Light stopped flashing and now it's just slipping. What do you mean by cut wires? Electrical?
Old 08-30-2014, 06:54 PM
FI460's Avatar
FI460
FI460 is offline
I think you need more posts before you can post photos with the site host.
Get a photobucket or dropbox and upload them there, than you can post them here.
Old 08-30-2014, 07:40 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
Not trying to be a jerk or smart a$$, but just to rule out the obvious, did you get the level back to where it's suppose to be?
OD off light flashing means the trans has thrown a code, if you don't think you cut any wires or anything, you need to find a shop that can pull the code for you. Not every scanner can "talk" to our trucks, so if you can find someone who specializes in powerstrokes.
EDIT: or a reputable transmission shop. Also if you filled it did you use the proper fluid?
Old 08-30-2014, 08:02 PM
tunnelrat92
^ not being a smart *** at all, that is the exact kind of responce I was looking for, thank you!
Old 08-30-2014, 08:04 PM
tunnelrat92
Actually, Im pretty sure I shorted out a wire when I threw the led bar on top. It ****ed up my running lights. Problemishes solved?
Old 08-30-2014, 08:05 PM
fordpride's Avatar
fordpride
If yiu have a OD light flashing then get the code and let's not guess at what it is.
On the down side after driving for a week like that don't be surprised if yiu need a rebuild now.
Old 08-30-2014, 08:21 PM
tunnelrat92
That's what I'm thinkin ^^ just wanted some more opinions
Old 08-30-2014, 08:24 PM
tunnelrat92
And yea had the level back to normal when it happened, in neutral. Maybe the line is clogged?
Old 08-31-2014, 08:28 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
Tow wall light? Walls are really hard to tow.
Your truck doesn't have a tow/haul light. It does have an OD OFF light. When that light is flashing it means something is wrong with the transmission. High temperature is only one of about 50 reasons that the OD OFF light would flash.
Maybe, but that won't cause this problem.
When you checked the ATF level was the transmission warmed up, in park, and the engine running?
Old 08-31-2014, 09:00 AM
tunnelrat92
Yes it was warmed up, in neutral and running. I used one of those little wax sticks to temporarily clog the hole till I got the patch. Think that could have clogged the line?
Old 08-31-2014, 09:34 AM
Mark Kovalsky
That's possible. But if it did, that won't cause your problem. If you want to find out what's wrong you will need to get the codes read. The codes will stay in memory for about a month after the last time the light flashed.
Old 08-31-2014, 09:44 AM
tunnelrat92
Alright I'll go do that soon and let you know. Thanks everyone
caedo
07-31-2013 03:58 PM
68rs327
03-11-2010 08:40 PM
rtazz17
10-28-2009 06:08 PM
jrandalls
03-26-2008 05:25 PM
Marc150
02-25-2008 10:46 AM
Quick Reply: Hit trany coolan line with sawzall, patched it now tranny hesitating and slipping. HE
