Turn signal indicators (in dash) don't work
Ok, I don't know where to start looking to resolve this (minor) problem, but I'm hoping some of you do. On the 1992 F150 Custom I just bought (223k miles) the turn signal indicators in the dash (the green arrows) don't blink when the signals are on. When I turn on a blinker I hear the ticking and looking at the lamps on the outside of the truck, they are in fact blinking. However, neither direction lights up the green turn signal indicator arrows on the instrument panel.
My thoughts are that it's not a fuse as I would think that would cause the whole signal system to not work. And it seems like it would be highly coincidental for both bulbs to be burned out. But what else is there?
Thank you for any help you can provide!
Thanks for the suggestion!
Yes, I've tried it with the stalk for blinkers as well as the hazards. All lights on the outside of the truck blink when they should, but the indicators in the dash never do. I'm thinking based on previous comments that is probably bulbs out. It is a 22 year old truck, so I guess it's a possibility. I also don't see the brake indicator light come on, so that one is probably burned out too. I'll pull the bezel and instrument cluster soon and check it out. Hopefully that's all it is.
WarrensE350
10-06-2018 07:15 PM
montana_highboy
04-06-2009 04:31 PM
