1996 E350 turn signal flasher - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-02-2018, 08:54 PM
WarrensE350's Avatar
WarrensE350
WarrensE350 is offline
WarrensE350 is gaining momentum as a positive member of FTE.
Where the heck is it? I found the hazard flasher but zero luck finding a second one. Any help?
Hazards work, blinkers do not. Everything else works...
Old 10-06-2018, 07:02 PM
98Econoline150's Avatar
98Econoline150
98Econoline150 is online now
98Econoline150 is starting off with a positive reputation.
Should be a flasher module under the dash somewhere. I think it will be on the driver side, possibly behind the instrument cluster.
Old 10-06-2018, 07:10 PM
fordman75
fordman75 is offline
fordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to all
Do the turn signal lights come on but don't blink or nothing happens at all?
Old 10-06-2018, 07:15 PM
WarrensE350
I guess the hazards and turn signals run through the same flasher? Anyway, it turned out not to be a fuse or a flasher. Must have been a loose wire in the steering column because when I took off the cover and inspected the wiring, the blinkers started working again. I know the old saying about how problems that go away by themselves...you know the rest. I'm sure it will recur in the future.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
