Fuel pump relay 2004 EX?
It seems that my fuel pump is out. I went to start my EX and when i did it would not stay running but would idle rough then die. Started it again and it did the same thing and the fourth time it would turn over but not fire. So I decided it must fuel related.
I changed the fuel filter thinking maybe it was clogged and it is the cheapest fix for a possible fuel problem. Well after that the truck would turn over but not start. So I jumped in the forum to see if anything else might cause this problem. I read about the fuel pump relay, cam positioning sensor and of course the fuel pump.
Does anyone know where the fuel pump relay is on a 2004 Excursion 6.8l? Is there anything else i have not thought of relating to the fuel problem?
I have not checked pressure at the fuel rail and I could not hear the fuel pump run when the key was turned on, but i never heard it before.
If it is the fuel pump, can i just replace the actual pump or do i have to change the entire module?
Thanks for any help
Thanks for any help
Thanks for any help
Thanks for any help
My pump failure played out exactly as you described yours. I went with a Motorcraft replacement unit, once I got the correct one, my EX is a Cali spec rig without any under hood stickers indicating that.
You can just get the actual pump part of the unit for less money, I have no idea about other brand's reliability. Pretty simple job really once you empty the tank out.
tom yuenkel
12-14-2005 09:43 PM
Texas Ex
05-02-2004 10:47 PM
