tailgate cap
tailgate cap
Anyone know of a place to order the cap on the end of your tailgate? I was loading my quad in my truck yesterday and ripped part of it off and then while taking the rest off, I tore a lot of the tabs off. Also, bent my tailgate itself a little but nothing a rubber mallet cant fix up!
Here you go, listed for 2011, double check for your own vehicle:
Tousley ford
<table class="all-component-parts " cellSpacing="0"><thead><tr><th class="reference-code">No.</th><th class="part-number">Part #</th><th class="description">Part # / Description</th><th class="required-quantity">Qty Req.</th><th class="list-price">List Price</th><th class="our-price">Price</th><th class="buy"></th></tr></thead><tbody><tr class="part-row part-row-1-1 alternate hotspot-highlight-active" data-part-num="8C3Z-9940602-DA" data-pgr-idx="1" data-reference-code="1"><td class="reference-code"> 1 </td><td class="part-number">8C3Z-9940602-DA</td><td class="description">8C3Z-9940602-DA / Tailgate Molding, Rear8 FOOT BOX TAIL GATE; w/flex step adobe
</td><td class="required-quantity">1</td><td class="list-price">$228.65</td><td class="our-price">$150.91</td><td class="buy pp-nowrap"></td></tr><!--<tr class="part-row part-row-1-1 alternate "> <td class="reference-code"></td> <td colspan="4" class="specific_description">8 FOOT BOX TAIL GATE; w/flex step adobe
</td> <td class="buy"></td></tr>--><tr class="part-row part-row-1-1 hotspot-highlight-active" data-part-num="8C3Z-9940602-EA" data-pgr-idx="1" data-reference-code="1"><td class="reference-code"> 1 </td><td class="part-number">8C3Z-9940602-EA</td><td class="description">8C3Z-9940602-EA / Tailgate Molding, Rear8 FOOT BOX TAIL GATE; w/flex step black
</td><td class="required-quantity">1</td><td class="list-price">$85.35</td><td class="our-price">$56.33</td><td class="buy pp-nowrap"></td></tr><!--<tr class="part-row part-row-1-1 "> <td class="reference-code"></td> <td colspan="4" class="specific_description">8 FOOT BOX TAIL GATE; w/flex step black
</td> <td class="buy"></td></tr>--><tr class="part-row part-row-1-1 alternate hotspot-highlight-active" data-part-num="BC3Z-9940602-A" data-pgr-idx="1" data-reference-code="1"><td class="reference-code"> 1 </td><td class="part-number">BC3Z-9940602-A</td><td class="description">BC3Z-9940602-A / Tailgate Molding, Rear8 FOOT BOX TAIL GATE; w/o flex step adobe
</td><td class="required-quantity">1</td><td class="list-price">$80.68</td><td class="our-price">$53.25</td><td class="buy pp-nowrap"></td></tr><!--<tr class="part-row part-row-1-1 alternate "> <td class="reference-code"></td> <td colspan="4" class="specific_description">8 FOOT BOX TAIL GATE; w/o flex step adobe
</td> <td class="buy"></td></tr>--><tr class="part-row part-row-1-1 hotspot-highlight-active" data-part-num="BC3Z-9940602-B" data-pgr-idx="1" data-reference-code="1"><td class="reference-code"> 1 </td><td class="part-number">BC3Z-9940602-B</td><td class="description">BC3Z-9940602-B / Tailgate Molding, Rear8 FOOT BOX TAIL GATE; w/o flex step black
</td><td class="required-quantity">1</td><td class="list-price">$80.68</td><td class="our-price">$53.25</td><td class="buy pp-nowrap"></td></tr></tbody></table>
Tousley ford
I had a load of lumber slide out of my truck as I pulled away from a traffic light and take the cap with it. (Dang waxed studs)
I ordered a new one from AutoNation White Bear and installed it when it arrived.
It's been a while, But I don't remember it being very hard to replace, Mine was a 2017 with a tailgate step.
I've had to replace both of my plastic end caps as well. They became loose from normal opening and closing of thr tailgate. The problem is not replacing them. The way they are designed to attach to the tailgate on the exterior side is with plastic snap in studs. Over time those studs snap off and the cap becomes loose.
At $40 a piece to replace and knowing they will eventually break again makes one want to find a better solution.
On a side note is the center section that covers the step replaceable? I couldn't find a part number for that piece.
I have ordered a couple of them from A1 Auto via ebay. Here is the info:
The piece included the metal pins, total was $89.
Flex Step Upper Black Plastic Center Trim Moldi...
Item ID: 311975114129The piece included the metal pins, total was $89.
That appears to be the center part that attaches to the slide out steps. Correct?
Here is the actual link. The other link posted does not work correctly
https://www.ebay.com/itm/Flex-Step-U...gAAOSwKIhc~9g2
