tailgate cap
Old Aug 26, 2014 | 02:31 PM
hodge250's Avatar
hodge250
tailgate cap
Anyone know of a place to order the cap on the end of your tailgate? I was loading my quad in my truck yesterday and ripped part of it off and then while taking the rest off, I tore a lot of the tabs off. Also, bent my tailgate itself a little but nothing a rubber mallet cant fix up!
Old Aug 26, 2014 | 02:36 PM
djousma's Avatar
djousma
Here you go, listed for 2011, double check for your own vehicle:
Tousley ford
<table class="all-component-parts " cellSpacing="0"><thead><tr><th class="reference-code">No.</th><th class="part-number">Part #</th><th class="description">Part # / Description</th><th class="required-quantity">Qty Req.</th><th class="list-price">List Price</th><th class="our-price">Price</th><th class="buy"></th></tr></thead><tbody><tr class="part-row part-row-1-1 alternate hotspot-highlight-active" data-part-num="8C3Z-9940602-DA" data-pgr-idx="1" data-reference-code="1"><td class="reference-code"> 1 </td><td class="part-number">8C3Z-9940602-DA</td><td class="description">8C3Z-9940602-DA / Tailgate Molding, Rear8 FOOT BOX TAIL GATE; w/flex step adobe
</td><td class="required-quantity">1</td><td class="list-price">$228.65</td><td class="our-price">$150.91</td><td class="buy pp-nowrap"></td></tr><!--<tr class="part-row part-row-1-1 alternate "> <td class="reference-code"></td> <td colspan="4" class="specific_description">8 FOOT BOX TAIL GATE; w/flex step adobe
</td> <td class="buy"></td></tr>--><tr class="part-row part-row-1-1 hotspot-highlight-active" data-part-num="8C3Z-9940602-EA" data-pgr-idx="1" data-reference-code="1"><td class="reference-code"> 1 </td><td class="part-number">8C3Z-9940602-EA</td><td class="description">8C3Z-9940602-EA / Tailgate Molding, Rear8 FOOT BOX TAIL GATE; w/flex step black
</td><td class="required-quantity">1</td><td class="list-price">$85.35</td><td class="our-price">$56.33</td><td class="buy pp-nowrap"></td></tr><!--<tr class="part-row part-row-1-1 "> <td class="reference-code"></td> <td colspan="4" class="specific_description">8 FOOT BOX TAIL GATE; w/flex step black
</td> <td class="buy"></td></tr>--><tr class="part-row part-row-1-1 alternate hotspot-highlight-active" data-part-num="BC3Z-9940602-A" data-pgr-idx="1" data-reference-code="1"><td class="reference-code"> 1 </td><td class="part-number">BC3Z-9940602-A</td><td class="description">BC3Z-9940602-A / Tailgate Molding, Rear8 FOOT BOX TAIL GATE; w/o flex step adobe
</td><td class="required-quantity">1</td><td class="list-price">$80.68</td><td class="our-price">$53.25</td><td class="buy pp-nowrap"></td></tr><!--<tr class="part-row part-row-1-1 alternate "> <td class="reference-code"></td> <td colspan="4" class="specific_description">8 FOOT BOX TAIL GATE; w/o flex step adobe
</td> <td class="buy"></td></tr>--><tr class="part-row part-row-1-1 hotspot-highlight-active" data-part-num="BC3Z-9940602-B" data-pgr-idx="1" data-reference-code="1"><td class="reference-code"> 1 </td><td class="part-number">BC3Z-9940602-B</td><td class="description">BC3Z-9940602-B / Tailgate Molding, Rear8 FOOT BOX TAIL GATE; w/o flex step black
</td><td class="required-quantity">1</td><td class="list-price">$80.68</td><td class="our-price">$53.25</td><td class="buy pp-nowrap"></td></tr></tbody></table>
Old Aug 27, 2014 | 06:58 AM
hodge250's Avatar
hodge250
thanks, I will call them today
Old Aug 27, 2014 | 07:00 AM
720Deere's Avatar
720Deere
Oh boy, I hope it isn't adobe with a step!
Old May 18, 2015 | 03:42 PM
elkman2000's Avatar
elkman2000
Any tips on the r&r process? I broke mine too and bristle at the thought of paying the dealer to do the labor?
Old Jan 9, 2020 | 11:05 PM
Don Kerkow's Avatar
Don Kerkow
I have a 2011 F350 with the Flex Step Tailgate. I keep breaking off the ABS Molding pieces. Does anyone know if it is possible to buy metal replacement parts?
Old Jan 10, 2020 | 04:37 AM
Just Strokin's Avatar
Just Strokin
I know of no known metal parts. I have not seen anyone in this forum of the 1999-2016 SD/HD forum mention any.
Old Jan 10, 2020 | 08:02 AM
Painted Horse's Avatar
Painted Horse
I had a load of lumber slide out of my truck as I pulled away from a traffic light and take the cap with it. (Dang waxed studs)
I ordered a new one from AutoNation White Bear and installed it when it arrived.
It's been a while, But I don't remember it being very hard to replace, Mine was a 2017 with a tailgate step.
Old Jan 10, 2020 | 08:43 AM
dirthawg's Avatar
dirthawg
I've had to replace both of my plastic end caps as well. They became loose from normal opening and closing of thr tailgate. The problem is not replacing them. The way they are designed to attach to the tailgate on the exterior side is with plastic snap in studs. Over time those studs snap off and the cap becomes loose.
At $40 a piece to replace and knowing they will eventually break again makes one want to find a better solution.
On a side note is the center section that covers the step replaceable? I couldn't find a part number for that piece.
Old Jan 10, 2020 | 09:50 AM
Don Kerkow's Avatar
Don Kerkow
Thanks Larry. It is a real pain. I am a cattle farmer and am constantly hauling hay, so I spend a lit of time on the tailgate. I have had to replace these moldings at least 3 times. Anyway, done complaining now. Thanks for your reply.
Old Jan 10, 2020 | 09:56 AM
Don Kerkow's Avatar
Don Kerkow
I have ordered a couple of them from A1 Auto via ebay. Here is the info:
Flex Step Upper Black Plastic Center Trim Moldi...
Item ID: 311975114129
The piece included the metal pins, total was $89.
Old Jan 10, 2020 | 09:59 AM
dirthawg's Avatar
dirthawg
Thanks for the link!
Old Jan 10, 2020 | 11:34 AM
Just Strokin
That appears to be the center part that attaches to the slide out steps. Correct?
Here is the actual link. The other link posted does not work correctly
https://www.ebay.com/itm/Flex-Step-U...gAAOSwKIhc~9g2
Todd Christ
2004 - 2008 F150
Apr 17, 2017 10:20 PM
Supercab_Max
Ford Truck Parts for Sale
Mar 30, 2014 02:43 PM
DarrinGT
Dec 10, 2011 12:43 PM
The Freak
Nebraska Chapter
Feb 10, 2010 08:41 AM
5.0Torx
General Automotive Discussion
Oct 30, 2007 08:31 AM
