lifted f350 tires rub on leaf spring....new wheel offset
My lifted 96 f350 front tires rub when turned so far its only the driver side and turend to the left so....i want new wheels and tires any way so any one got an idea on what kinda off set i should go with to clear every thing?
On an F150 you can go with 15"x10". You can use the same offset there too, just understand that the TTB front end won't like the leverage that tires that far out will cause.
VERY common and even with 4-4.5" back spacing they typically still rub.
it is not an issue unless you are rubbing thins at any type of speed. But since they only run under FULL LOCK, there is no issue
Alright thank ya sir! I'm gonna go with 16 inch rims that way I can get a taller and narrower tire... Like a 285 75 16.
