fuel system problem
Old 08-23-2014, 11:34 AM
gMT1943's Avatar
gMT1943
gMT1943 is offline
Question fuel system problem
My 2003 350 super duty indicates that I need to drain water from the fuel system. The 6 mm hex socket in the drain plug has been ruined. Any help would be appreciated.
Old 08-23-2014, 11:52 AM
mhoefer's Avatar
mhoefer
mhoefer is offline
You need an easy out that fits and buy the prper updated plug with only a knurled **** on it. Once you easy out it, have the new plug and a catch basis waiting. The trick with an easy out is pressure to make it grip, it's like a drill bit in reverse which will bite and get it loose. The updated part is on this site if you search and it's easier to use. It does not need to be very tight, it has a no ring which provides the seal against the fuel. Tighten with your hand only and you won't have more trouble. I had to do the same after 8 years of draining and 100 k miles or so.
gMT1943
1999 to 2016 Super Duty
08-24-2014 04:21 PM
bbender85
02-05-2014 09:45 PM
LionInTheSun
05-05-2011 06:27 AM
thralkhan
08-18-2010 09:26 AM
Black1
05-16-2007 10:08 PM
Quick Reply: fuel system problem
