fuel system problem
Old Aug 23, 2014 | 11:34 AM
gMT1943's Avatar
gMT1943
Question fuel system problem
My 2003 350 super duty indicates that I need to drain water from the fuel system. The 6 mm hex socket in the drain plug has been ruined. Any help would be appreciated.
Old Aug 23, 2014 | 11:52 AM
mhoefer's Avatar
mhoefer
You need an easy out that fits and buy the prper updated plug with only a knurled **** on it. Once you easy out it, have the new plug and a catch basis waiting. The trick with an easy out is pressure to make it grip, it's like a drill bit in reverse which will bite and get it loose. The updated part is on this site if you search and it's easier to use. It does not need to be very tight, it has a no ring which provides the seal against the fuel. Tighten with your hand only and you won't have more trouble. I had to do the same after 8 years of draining and 100 k miles or so.
gMT1943
Aug 24, 2014 04:21 PM
bbender85
Feb 5, 2014 09:45 PM
LionInTheSun
May 5, 2011 06:27 AM
thralkhan
Aug 18, 2010 09:26 AM
Black1
May 16, 2007 10:08 PM
