1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2015 F350 DRW 6.7 Diesel Towing
Old 08-24-2014, 06:35 PM
lb27312's Avatar
lb27312
lb27312 is offline
I am picking up the truck tomorrow. When I put in the VIN in the VIN Decoder on this site it is saying the maximum towing weight is 12,200 lbs. The reason I went with the 2015 was the advertised towing capacity. The sticker says it has the tow package and the gooseneck/5th wheel prep package so I thought I was good with the new higher tow rating. Could the VIN Decoder be wrong? I looked at the specs on the Ford website and it says 19k towing.....
Any ideas would be appreciated. I have a 2004 F350 DRW with the 6.0. I love that vehicle but picked up a new trailer that with it loaded is close to the tow capacity which is why the change.
Thanks
Old 08-24-2014, 07:00 PM
Tom's Avatar
Tom
Tom is online now
Hi ib, welcome to FTE!
Not sure which VIN decoder you're using, but it's most definitely not going to be more accurate than the manufacturer specs. Yes, the VIN decoder is wrong.
Your truck is rated for 19,000 lbs, you picked the right one.
Old 08-24-2014, 07:57 PM
lb27312's Avatar
lb27312
lb27312 is offline
Thank you Tom!! I really appreciate it. I know it was a stupid question but I thought maybe the VIN decoder was telling me I didn't look at the truck close enough.
This is a great forum and have learned a ton of information from here.
Old 08-25-2014, 05:16 AM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
It might only be thinking off the receiver, not the gooseneck.
Congrats!
Old 08-25-2014, 06:30 AM
Tom's Avatar
Tom
Tom is online now
Nope, not even that. The 172" WB DRW trucks get an 18,500 lb hitch, and the shorter wheelbase models get a 15,000 lb hitch. But all of the DRW diesel trucks regardless of wheelbase are rated to 19,000 lbs conventional towing.
Old 08-25-2014, 10:06 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
The odd thing is, the only 5th wheel hitch you could order with a 2011 irregardless of model or engine was a 25k.
CHJ
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
11-10-2018 09:25 PM
Powerplay13
2017+ Super Duty
12-08-2017 03:18 PM
Benny76
10-17-2016 08:45 AM
montyv
08-03-2012 01:05 PM
Jim McCarty
1997 - 2003 F150
07-19-2003 07:33 PM
Quick Reply: 2015 F350 DRW 6.7 Diesel Towing
