vin decode please
Old Aug 3, 2012 | 12:47 PM
montyv's Avatar
montyv
vin decode please
I have a 1986 F150 supercab 2wd with the V8 302 5.0L engine. I am trying to figure out what kind of airstream i can tow. but I cannot pin down the type of transmission, rear end and rating for towing.
vin is 1FTEX15N1GKB21209
when i run it through the vin function on this site it tells me to enter a vin but doensn't give any information.
thanks
Old Aug 3, 2012 | 12:59 PM
ctubutis's Avatar
ctubutis
You can plug your VIN to here:
https://www.fleet.ford.com/maintenan...ls/default.asp
It will give you a bit more information, but the kind of stuff you're looking for can't be determined by just the VIN on something this old.
If you post a picture of the Certification Label on the driver's side door jamb, we can tell you more about what you have.
I have to say, though, an F150 with a 302, I don't know I'd recommend that for towing something as big as an Airstream.
Others will be able to say more.
Old Aug 3, 2012 | 01:05 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Yep, the VIN will only tell us what engine it has, which you already said was a 302 EFI.
All of the info that pertains to your intended purpose is contained on the cert label.
However, if this truck has the AOD 4 speed auto, I wouldn't advise towing much with it. Certainly not an airstream, particularly in OD.
smolenr
2015 - 2020 F150
Jun 7, 2019 06:17 AM
bobsmith69
2009 - 2014 F150
Jun 14, 2017 12:37 PM
MikeB 88
1983 - 2012 Ranger & B-Series
Aug 21, 2014 06:00 PM
Waltg78
Feb 29, 2008 08:12 PM
grandaddy's66
Jan 25, 2004 08:07 AM
