1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
05 F 250 front axle snap ring tool
Old 08-21-2014, 09:23 PM
mtnxtreme's Avatar
mtnxtreme
mtnxtreme is offline
I broke 2 snap ring plier on this thing can anyone tell me the make and model of snap ring pliers used to remove the snap ring off axle in hub ? I have some others but too beefy won't move in there. They need to be long but strong. I've heard Snap On Item: SRPC9000A works but I don't know of any Snap On guys around here and I need to get this thing done. Any ideas ? Thanks.
Old 08-21-2014, 09:47 PM
skanj0's Avatar
skanj0
skanj0 is offline
I went through this 2 months ago. Those snap rings are a nightmare. I looked up snap-on, and found a mobile tool truck a few miles from me. If they aren't busy they might even come to your location. Thank goodness for these snap ring pliers.
Old 08-22-2014, 03:53 AM
05F250DSL's Avatar
05F250DSL
05F250DSL is offline
I just did my complete front end on my 05'. I will have to get to work and try to see a number on my pliers. I actually had to take my snap-on set remove the rubber on the handles heat them and bent the handles straight to ge enough pull. Until I figured that out I broke a few $40 sets of lisle pliers and had many choice words. It took longer messing around with the first snap ring than it did to press out and in the ball joints and swap the bearing and seal.
Old 08-22-2014, 06:01 AM
mtnxtreme's Avatar
mtnxtreme
I dad a nice old KD set used for years on some pretty heavy stuff, snapped the tips twice. Snap On ? I live ina very rural area, but every post I read comes back to them. Maybe M-Chan will chime in he does these every day !
Old 08-22-2014, 06:39 AM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
check online for snap-on. I have several of their tools.
Old 08-22-2014, 11:04 AM
Denola's Avatar
Denola
Denola is offline
I went through the same thing when I changed the hub/bearing assy on my 08'. Once I did get the snap rings off, I took a grinder and ground off the flat ends to a slant (l=/) to where I could use a pair of regular lock ring pliers to install the new ones. Worked well, and will come off next time easier also, Dennis.
Old 08-24-2014, 08:14 AM
05F250DSL's Avatar
05F250DSL
Unfortunately the numbers on my snap ring pliers are worn off. I did buy them from the snap on truck but over the years the part number is gone.
Old 08-24-2014, 04:11 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Can you post a photo of them with a ruler in
the photo to give size?
Sean
Old 08-25-2014, 09:56 AM
Iron2's Avatar
Iron2
Iron2 is offline
I bought some piston ring pliers from NAPA and ground the tip to the shape I wanted.
Old 08-26-2014, 09:42 AM
mtnxtreme's Avatar
mtnxtreme
OK I went to a large truck parts store and they had these http://www.ebay.com/itm/K-Tool-International-KTI-55123-090in-Straight-Tip-Snap-Ring-Plier-kti55123-/390867745676?pt=Pliers&hash=item5b01887b8c
KTI-55123 .090 they do external and internal, feel heavy in hand and must be hardened steel, because the didn't even flex and they have extended tips so they don't even touch the axle or hub. $17.99 on e-bay, I paid $25.00 at the truck parts store and thats at least half of what the Snap On ones cost of which I heard can break from a few guys on here. Hope this helps someone on here that runs into a brick wall like I did.
Old 08-26-2014, 12:27 PM
05F250DSL's Avatar
05F250DSL
I found the number on the pliers it is srpc7000 but as mentioned I removed the grips heated and straightened the handles to get them to work well. Where the very end of the handle towards your wrist if you are holding them touch you need just a little more pull. Then they worked great. If they had a set a little longer from pivot to tip and still just as narrow they would be the ones to get. I'm not good with the picture thing but these are 2 and1/16th from center of pivot to tip
donp68
11-26-2015 11:17 AM
wy4525
06-11-2015 02:35 PM
run6.0run
39
01-20-2012 09:27 AM
wideglidewoody00
15
08-06-2009 09:29 AM
Orezona
11-19-2006 08:04 PM
Quick Reply: 05 F 250 front axle snap ring tool
