How many leaf's in a 65 F-100 rear spring?
I've seen photos of the undersides of some F-100's and comparing rear springs mine has several more than stock. The PO said he added extras but what is stock I count 9 leaf's and no more room on the U-bolts for more.
Did he try to make an F-250 out of it? It has some really big air shocks back there also.
Here is a photo, check it out.
It depended on the load capacity the truck was set up for from the factory. There were 3 choices on 1965 F100 2x4.
Standard - 950 lbs - 5 leaves
Option 1 - 1250 lbs - 6 leaves
Option 2 - 1650 lbs - 9 leaves
There was also an auxiliary rear spring available with a 380 lbs capacity. This option was not available with the 1650 lbs rear spring option.
If you got the auxiliary springs then the U-bolts point downwards, otherwise, upwards.
TheWiz427
18
11-14-2007 11:36 AM
rustfarmer
04-07-2007 02:41 PM
