2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
1 Way Remote Start and key/fob consolidation on 2014 Expedition
Old 08-18-2014, 01:05 PM
steveg_nh's Avatar
steveg_nh
steveg_nh is offline
Hi All,
I’ve had probably reviewed over 100 threads on remote starts and programming new fobs, but unfortunately I haven’t been able to answer my question. I hope you can all help. The backdrop:
* 2014 Expedition Limited with factory installed remote start (the 1 way, single button plug n play system).
* Truck has factory keyless and security system, so the add on was just the remote start module
* I currently have the 4 button key/fob combo and the single button remote start (see pic)
* Being a new Expedition, it’s an 80 bit security key
I read a lot of threads about people being able to reprogram their Expedition so the factory Ford fob also performs the remote start, so they can eliminate carrying two or three keys/fobs. Can I do this with my current key/fob combo somehow?
Or even better, I found this key/fob combo available online, which has the integrated remote start option as a 5th button.
Can I program this to perform the remote start? Information online regarding this key is limited. The seller says it can be used if my Expedition came with that exact model, yet as far as I know, NO Expedition with factory remote start comes with a 5 button key/fob combo.
I’m hopeful it’s as easy as programming the new key for ignition and remote functions, and then just “learning” the remote start button through the programming menu of the remote start system. I just can't determine if the frequencies will match, if I have to reprogram remote start to use two button presses (vs long hold) to start, etc, stuff like that
Any help is appreciated.
Thanks
Old 11-26-2014, 10:42 PM
riverstroker04's Avatar
riverstroker04
riverstroker04 is offline
did you have any luck with this?? I have the same system!
Old 11-26-2014, 11:31 PM
steveg_nh's Avatar
steveg_nh
Nope. I never bought the key to try it. Since it's a separate fob now, my confidence wasn't high in the RMST system being able to work with the Ford key.
jdunk54nl
2017+ Super Duty
27
02-22-2021 02:46 PM
Sarge261
2009 - 2014 F150
11-28-2018 02:46 PM
pm465
2009 - 2014 F150
12-22-2017 08:24 PM
hldr
03-23-2017 10:34 PM
Quick Reply: 1 Way Remote Start and key/fob consolidation on 2014 Expedition
