Aerostar Ford Aerostar
Aerostar axle widths and type?
Old 08-17-2014, 06:30 PM
carnuck's Avatar
carnuck
carnuck is offline
I'm looking for a replacement diff for my "other" truck that is fairly strong (9" or 8.8), 4.10 ratio and correct width (@60") with 5 lug pattern. Explorer is close but the ratio seems hard to find or very expensive.
Old 08-23-2014, 06:05 PM
asavage's Avatar
asavage
asavage is offline
I had a 4.10 Trak-Loc in my '89 EB, but they're a 7.5" and definitely not strong. The Trak-Loc version tends to oval one of the spider shaft bores in the ring carrier and you get a rattle. And mine had significant decel pinion bearing noise at around 300k miles.
Is the 8.8" from a 4.0l 2WD Aero available in 4.10 ?
[later]
I don't think so. The only 4.10 ratios I see are for the 7.5" diffs in Aeros, according to this list I got from somewhere years back. The comments are not mine:
Old 08-24-2014, 03:49 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
Gee, did some Aerostars actually come with aluminum rear axle housings? I know the front axle on my AWD is a Dana 28, and I think it is aluminum. But I don't think I've ever seen one with an aluminum rear axle housing.
Previously I had looked for LSD 8.8" axles with 3.73 ratio, and could not find any. If your list is all-inclusive, that explains why. I was hoping to replace the 7.5" rear axle with an 8.8" of the same ratio, and with a LSD.
Old 08-24-2014, 06:56 PM
asavage's Avatar
asavage
asavage is offline
I got that list -- with the comments attached -- off the internet, it's not my quote or research.
I don't think the Dana 30 is a rear diff.
Old 08-24-2014, 11:43 PM
RojoStar's Avatar
RojoStar
RojoStar is offline
The 8.8 3.73 LSD can be found on the Explorer D4 axle, and mine is still waiting for adaption to the Aero.
Comes with disc brakes too.
Project delayed until early 2015, to be usable by summer.
Old 08-25-2014, 02:12 AM
xlt4wd90's Avatar
xlt4wd90
I knew they must exist somewhere.
How are you planning to make the adapting?
Old 08-25-2014, 08:48 AM
RojoStar's Avatar
RojoStar
RojoStar is offline
Yes, I'm an engineer with a welder, and my Exp front brake adaption is still working flawlessly.
The big-tube 8.8 w/discs is way heavier than the Aero 7.5.
From lifting just one end, I expect the total to come in at around 250lbs.
Surprise, this '97 example needs to be widened, not narrowed, to match the Aero track.
If and when, the project will go into the Built-to-tow thread.
Old 08-25-2014, 05:47 PM
xlt4wd90's Avatar
xlt4wd90
Maybe you've posted this before, and I missed it, but can you describe your front brake modification? Or provide a link to anything you've posted before?
Old 08-25-2014, 06:07 PM
RojoStar's Avatar
RojoStar
RojoStar is offline
I'm sure you'll remember Explorer Brakes On An Aerostar.
Fronts currently overshadow the weaker (10") rear drums.
The inbound rear discs will then become too strong with the stock MC and need the Exp MC to balance correctly.
And one Exp MC has bias adjust.
Old 08-26-2014, 08:04 PM
xlt4wd90's Avatar
xlt4wd90
Thanks Rojo, I can't believe I forgot about that. (and I've commented on it as well).
f150owner
General Automotive Discussion
12-11-2005 12:55 PM
scouterspokane
11-26-2005 04:24 PM
justinhorn
04-02-2005 10:40 AM
1986 truck and driver
08-27-2003 08:56 PM
garyto72
1978 - 1996 Big Bronco
08-10-2002 01:54 PM
Quick Reply: Aerostar axle widths and type?
