1950 f1 numbers
Welcome to the forum. There's a very lengthy thread on the subject. In that string of numbers is your color code, assembly plant, date code and other information. The SP would indicate St. Paul assembly plant. You appear to have way more numbers than is the norm. Post the info and other requested details in the thread here..
https://www.ford-trucks.com/forums/4...n-cut-off.html
15 could be light gray. Knowing the color of your truck and serial number would help as SP used numbers for awhile before going to letters for the color.
Most have a stamping something like 15 SP 12L 2345
Sometimes lightly sanding the stamping will bring out details. Shining a light on a shallow angle can also help. Post a clear - if you can.
keithbutts
03-07-2019 11:42 AM
Dan Rose
11-03-2014 03:06 PM
Ste14mi
09-22-2013 07:46 PM
homade
23
12-17-2012 10:09 PM
